Situation
I’m trying to set up something fairly simple I think. I am using a Technicolor cable modem to connect to the internet. I had to call my ISP to get it in bridge modem but that’s working fine now. The DHCP client on ether1 is getting a public IP now and I can access the internet. The thing is that some websites are not reachable through http(s). Which indicates something is wrong with my NAT/Firewall rules I think.
WAN <==> [Bridged technicolor cable modem] <==DHCP==> Mikrotik RB2011 <========> 192.168.0.1/24 & 10.0.0.1/24 (VLAN100)
Things I tried
- Setting the MTU to a lower value (1400), didn’t work
- Adding MSS mangle rules, didn’t work
Debugging
Wireshark does show (RST, ACK) flags being sent so at least I can see that something is wrong. It can’t be a DNS issue as I can ping all websites, it is just http communication. These are the relevant parts of the config (I think), I really do hope someone can help me.
DHCP Client
/ip dhcp-client
add dhcp-options=clientid,hostname disabled=no interface=ether1 use-peer-ntp=no
Firewall
add action=accept chain=input comment="accept established connection packets" \
connection-state=established
add action=accept chain=input comment="accept related connection packets" \
connection-state=related
add action=accept chain=input comment="Accept established related" \
add action=accept chain=input comment="Allow LAN access to router and Internet" \
in-interface=bridge-LAN
add action=accept chain=input comment="Allow ping ICMP from anywhere" protocol=\
icmp
add action=accept chain=forward comment="Accept established related" \
"Allow LAN access to router and Internet" connection-state=new \
add action=accept chain=forward comment="Accept Port forwards" \
connection-nat-state=dstnat in-interface=ether1
add action=drop chain=input comment="Drop all other input" log-prefix=input
add action=drop chain=forward comment="Drop all other forward" log-prefix=fwd
/ip firewall mangle
add action=change-mss chain=forward new-mss=1360 protocol=tcp tcp-flags=syn \
tcp-mss=1361-65535
add action=masquerade chain=srcnat src-address=192.168.0.0/24
add action=dst-nat chain=dstnat comment=rpi dst-port=22 protocol=tcp \
to-addresses=192.168.0.10 to-ports=22
add action=dst-nat chain=dstnat comment="rpi admin" dst-port=2222 protocol=tcp \
to-addresses=192.168.0.10 to-ports=22222
add action=masquerade chain=srcnat comment="TEMP " disabled=yes src-address=\
10.0.0.0/24
Edit\ Could it have something to do with ARP perhaps?
