While scanning for AP’s from my Metal in CPE - Router mode I see this in the Quick Set screen and am not able to connect to any AP to get access. I have looked thru the WiKi and am not able to find the description of the color coding in the screen shot. The Blue is my internal AP for connections from my tablets and laptops. i am assuming the Green is good, and Orange is something other than good.
When scanning for AP’s, is it the Blue ones I am looking for or Green?
What does Orange mean?
The AP’s with intermittent Green and Orange mean what.
I do see some Red and figure that is No Good. Is that correct?
I have just entered Canada and have read that the US and Canada use the same frequencies. As my Metal only allows US in the pick list. Also disregard the Band as I have tried the less restrictive and received the same results. It appears that all the available AP’s are using N.
-Bill
