Some PCs without internet on LAN, but if you switch to WLAN it's works
Hi!
For the last couple of weeks, I’ve been having trouble accessing the Internet on some PCs. They are getting IP and DNS. Arises by itself, I have not found any dependencies for this problem, but there are a couple of patterns to fix, sometimes it helps to restart the adapter / pc, change the MAC address, issuing a static address, but after some time they kick out again. If you connect via a Wi-Fi adapter to the network of the same Mikrotik, everything works without fail. Problems at the physical level are excluded. As a quick fix - put a TP-Link (heh) between the Mikrotik and the switch, and everything works fine.
There are suspicions that it may be due to changes in configuration at the ISP. I also have some questions about it, but for now, I want to figure out what the problem is with the local network.
Router Model: hAP ac³
Switch Model: Tenda TEG1024G
Config:
# jan/05/2023 12:14:33 by RouterOS 6.48.6
# model = RBD53iG-5HacD2HnD
add admin-mac=48:**:*:**:**:2E auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country="united states" disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid=Home wireless-protocol=\
    802.11
set [ find default-name=wlan2 ] band=5ghz-n/ac channel-width=20/40/80mhz-Ceee \
    installation=indoor mode=ap-bridge ssid=Home_5G wireless-protocol=\
    802.11
set [ find default-name=ether1 ] mac-address=B0:**:**:**:**:3E name=\
    wan_lionline
set [ find default-name=ether2 ] mac-address=48:**:**:**:**:2D name=\
    wan_reserve
/interface vlan
add interface=wan_lionline name=vlan-l vlan-id=942
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.0.10-192.168.0.250
add address-pool=dhcp disabled=no interface=bridge lease-time=23h59m59s name=\
    defconf
add bridge=bridge comment=defconf interface=wlan2
add comment=defconf interface=vlan-l list=WAN
add address=192.168.0.1/24 comment=defconf interface=bridge network=\
    192.168.0.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add add-default-route=no comment=defconf disabled=no interface=wan_lionline \
    use-peer-ntp=no
add address=192.168.0.0/24 comment=defconf gateway=192.168.0.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.0.1 comment=defconf name=router.lan
*DEFAULT CONFIG*
add check-gateway=ping distance=1 gateway=wan_lionline
