My Mikrotik allow web surfing to any site from PC behind the firewall.
HOWEVER: just one is unreachable. It is reachable from other LAN (not Mikrotik based).
PC behind MK router/firewall:
[giuseppe@godzilla ~]$ curl -v -k https://www.easyplansb.it:8443/easyplanweb/mvc/EasyPlanSB.html
* Adding handle: conn: 0x206b930
* Adding handle: send: 0
* Adding handle: recv: 0
* Curl_addHandleToPipeline: length: 1
* - Conn 0 (0x206b930) send_pipe: 1, recv_pipe: 0
* About to connect() to www.easyplansb.it port 8443 (#0)
* Trying 5.196.204.34...
* Connection timed out
* Failed connect to www.easyplansb.it:8443; Connection timed out
* Closing connection 0
curl: (7) Failed connect to www.easyplansb.it:8443; Connection timed out
From other PC not behind th MK router:
giuseppe at fukuoka>curl -v -k https://www.easyplansb.it:8443/easyplanweb/mvc/EasyPlanSB.html
* Connected to www.easyplansb.it (5.196.204.34) port 8443 (#0)
* Initializing NSS with certpath: sql:/etc/pki/nssdb
* skipping SSL peer certificate verification
* ALPN/NPN, server did not agree to a protocol
* SSL connection using TLS_RSA_WITH_AES_128_CBC_SHA
* Server certificate:
* subject: CN=web.easyplansb.it,OU=Sabacom Small Business,O=Sabacom s.r.l.,L=Taranto,ST=Taranto,C=IT
* start date: Feb 08 14:03:28 2012 GMT
* expire date: Jan 15 14:03:28 2112 GMT
* common name: web.easyplansb.it
* issuer: CN=web.easyplansb.it,OU=Sabacom Small Business,O=Sabacom s.r.l.,L=Taranto,ST=Taranto,C=IT
> GET /easyplanweb/mvc/EasyPlanSB.html HTTP/1.1
Other https sites work well, e.g. from the same PC behind MK:
[giuseppe@godzilla ~]$ curl -k -v https://www.google.com
* Rebuilt URL to: https://www.google.com/
* Adding handle: conn: 0x1960840
* - Conn 0 (0x1960840) send_pipe: 1, recv_pipe: 0
* About to connect() to www.google.com port 443 (#0)
* Trying 216.58.198.4...
* Connected to www.google.com (216.58.198.4) port 443 (#0)
