Some SXT Lite2 in one network by wireless, need sth more?
I have five SXT Lite2, four IP-cameras and one network videorecorder. I’ve planned connect each SXT Lite2 to each device, but SXT Lite2 which near network videorecorder set up as main, others as slave. Is it enogh or I need to replace last SXT Lite2 with GrooveA or SXT 2?
CPE mode means only CPE client mode support?
Is it possible to set one as a bridge, and others as a stations?
Thanks for answers.
If lite version has only level 3 license you cannot use it as Ap. You need at least license level 4 for that. It is smart to have dual chain Ap if you use dual chain clients. So look this way…
License Level 3 accepts making two or more bridges on one SXT Lite2?
Ok, I got this idea as a variant, thanks.
Bridges are not limited.
