Hi there,
Noob question here so apologies. I recently moved into a new house here in the UK that is only provided by OFNL. I previously used my MikroTik Hex5 with my old ISP on PPPOE with no issues.
For the move, I factory reset it and have connected it to the OFNL Fibre box and then into WAN/eth1. Eth2 then goes to my Eero for WIFI and ETH3 goes to my switch for the ethernet ports in the house.
Initially I had an issue with Geolocking as my property was being assigned IP addresses from a range that previously belonged to an USA company which got sorted. I’m now in a situation where a few websites in particular (which I use as part of my job) do not load or they load then stop working after a few seconds. I have raised this with my ISP and after a few mentions of MTU and MSS Clamping, I decided to look into this in a bit more detail. This seemed to add up as I’ve read detect VPN usage (to prevent unauthorised location access) via MTU value changing.
When I run Ping -D -s xxxx www..com the value I get to before I get a frag needed error is 1452. I have reported this to my ISP but they don’t seem interested in this anymore. They have said the fix is regarding DNS and that my DNS servers need to be 8.8.8.8 and 8.8.4.4. In RouterOS, I have added these in, both in DNS and then DHCP Server > Networks and have turned off DNS peer but still no luck. I’m at a point now where they want to charge me £15 per 15 minutes to diagnose this issue because I’m using a non-ISP router and the DNS issue has fixed this issue for all other customers, the only differentiater is that I’m not using their router. Before I cave into their demand I thought I’d seek assistance here as the hardware functioned fine on PPPOE at my old property.
RouterOS v7.13.5
Current MTU on pppoe-out1 is 1480
MTU on Bridge, Eth1, Eth2, Eth3, Eth4, Eth5 is all 1500.
Thanks in advance
# 2024-02-28 17:30:27 by RouterOS 7.13.5
# software id = 7EUS-LBI8
# model = RB750Gr3
# serial number = 123456789
add admin-mac=B8:69:F4:7F:2A:2A auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 user=\
pppoe_username
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.88.2-192.168.88.254
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/port
set 0 name=serial0
192.168.88.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1 use-peer-dns=no
add address=192.168.88.0/24 comment=defconf dns-server=8.8.8.8,8.8.4.4 \
gateway=192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip firewall mangle
add action=change-mss chain=forward new-mss=clamp-to-pmtu passthrough=yes \
protocol=tcp tcp-flags=syn
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/London
/system identity
set name=3EspinClose-MikroTik
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
