Some websites would not load
Hello, I have a network of a few computers and some websites would not load, its a problem with the router Mikrotik 750g, i tried plugging internet cable directly into a computer and that way all websites load. Im guessing its a problem with MTU values, or something else ?
not enough information. if you use pppoe or other tunnel check that change-mss rules are present, if no then it might be DNS server problem.
Im guessing it isnt a dns problem because when I plug the cable directly in a computer all sites load, static IPs are set in both cases. Which information should i provide ?
Try with latest RouterOs 6.26
