Hi
Have a PTP link (2 x LHG 5ac’s) connected but not too happy re performance which I am sure is due to my limited knowledge on wireless and asking for some help.
The distance between the devices is about 500m with clear line of sight, both devices are on ROS 6.44.1.
I if I can get the link to push through 500 - 600Mb/s or more data throughput, not radio speed, I will be happy and my thinking is that the LHG 5ac should be capable of this at this short distance?
Below link info:
Station Side:
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=MySecret supplicant-identity=MikroTik wpa2-pre-shared-key=MySecret
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=15 band=5ghz-onlyac channel-width=20/40mhz-Ce country="south africa" disabled=no frequency=auto \
frequency-mode=regulatory-domain installation=outdoor mode=station-bridge radio-name=MySecret security-profile=MySecret ssid=MySecret \
wireless-protocol=802.11 wps-mode=disabled
/interface wireless align
set receive-all=yes ssid-all=yes
status: connected-to-ess
channel: 5805/20-Ce/ac(15dBm)
wireless-protocol: 802.11
tx-rate: 360Mbps-40MHz/2S
rx-rate: 400Mbps-40MHz/2S/SGI
ssid: MySecret
bssid: MySecret
radio-name: MySecret
signal-strength: -42dBm
signal-strength-ch0: -44dBm
signal-strength-ch1: -46dBm
tx-signal-strength: -43dBm
tx-signal-strength-ch0: -46dBm
tx-signal-strength-ch1: -46dBm
noise-floor: -106dBm
signal-to-noise: 64dB
tx-ccq: 85%
rx-ccq: 89%
p-throughput: 261248
overall-tx-ccq: 85%
authenticated-clients: 1
current-distance: 1
wds-link: no
Bridge AP Side:
/interface wireless
frequency-mode=regulatory-domain installation=outdoor mode=bridge radio-name=MySecret security-profile=MySecret ssid=MySecret wireless-protocol=\
status: running-ap
overall-tx-ccq: 99%
registered-clients: 1
current-distance: 35
wmm-enabled: yes
notify-external-fdb: no
The questions are:
- My first aim is to make sure the devices are aligned properly, does the “Alignment Mode” still work, I tried it and cant see anything on the station side (Winbox Interface) or get any beeps/sound when I try it standing right below the device, maybe I am doing it wrong, don’t know, followed this video https://www.youtube.com/watch?v=6_D91n9iWO8
- This might be a “How long is a piece of string” type question, but is there anything from info provided that you can see wrong or suggest some improvements, if you need more info, I will provide.
