Hello, i have problem whit last version OS7 only work for me in 7.1.5
after update can access this web sites:
h…porvenir.com.co
h…s16.movilsp.co
can’t login or can login but can play any program
h…directvgo.com
h…hbomax.com/co/
I use PPPoE and speed control by PCQ
I have CCR2116-12G-4S+ can’t downgrade
and have CCR2004-1G-12S+2XS 6.49.6 work very fine this web site, if upgrade to 7.2 7.3 7.4 have same problem.
can someone confirm if you get the same problem with those versions
thanks.
Is not MikroTik related
403 ERROR
The request could not be satisfied.
Request blocked. We can't connect to the server for this app or website at this time. There might be too much traffic or a configuration error. Try again later, or contact the app or website owner.
If you provide content to customers through CloudFront, you can find steps to troubleshoot and help prevent this error by reviewing the CloudFront documentation.
Generated by cloudfront (CloudFront)
Whit version 6.49.6 work fine, but 7.4.1 no work.
From what I can tell there is a geo block and maybe some browser weirdness. If I try to access the directvgo site from my current location I get the error that @rextended noted. If I enable a vpn putting me in the US it works. If I use Safari to go to the hbomax site, it tells me the service isn’t available in my area whether I use the vpn or not. If I use chrome, it works regardless. I’m using 7.4.1 on all my MikroTik devices.
Porvenir only works for me if I use a vpn with an endpoint in the US.
s16.movilsp.co works for me without the need of a vpn.
