My first contact on watchdog-reboot in mikrotik v.6.xx is 13-09-2014.
Since then I replaced the support of more than 16 email.
2 S. Martins mail
1 email with Kristaps S.
10 mail Uldis
And at the end of one email from Janis B. To which I replied. But since 10-10-2014 I did not get an answer.
I sent them the 20-30 supout.rif
Zaaktualizowałem few devices (711, Lite5, 2011iL, etc..) To version 6.xx (6.7, 6.19, now 6.20).
When the work day, or two days can restart themselves. (disable watchdog suspends the device).
Sometimes when you enter the device from the MT v6.xx causes restart.
Sometimes supout.rif generating device with MT v6.xx causes restart.
Sometimes when you export the configuration to the device MT v6.xx causes restart.
Support recommending disable snmp, api - I made it - did not help.
Support recommending the inclusion of rstp - I made it - did not help.
I also have a lot adjoining equipment on the MT v5.26 and running. Any errors. Uptime of 100 days and more.
This is really ridiculous on their part. No information. No solution to the problem. No stable software. Do not refined.
Sell equipment that does not work well.
You test software on their clients. On what world you live?
Maybe I just was already beyond software development? Maybe it’s time to give this project the people who know their stuff?
Please solution to my problem, because for such problems losing customers, good reviews.
I am terribly pissed off at your software. Although this is a very nice solution.
I have similar experience but only with 32mb devices running 6.x. The are choking probably by insufficient memory and one of them doesn’t manage to work with USB flash disk that worked without problems before upgrade. The devices stay for some time 5-80min on 100 %cpu with bad response times and after that they work normally without restart. Sometimes restart helps immediately. Not possible to produce supout file as it doesn’t finish. I even let janis b to login and look at it two weeks ago - no info since then.
I had same problem with rb951 which was rebooting every few hours and in log there was no reason except that it was rebooted by watchdog. In case I disable watchdog board just hung and then I needed to cut the power off.
Tried everything and nothing helped. The only thing I noticed is that total sector writes variable was incredibly high.
The only thing that helped is taking it to local dealer who gave me another one
Day 08-09-2014 upgrade 2x RB711G-5HnD (sextant), 4x Lite5, 2x RB711-5Hn, 1x RB2011LS, 3x RB2011iL, 2x SXT G-5HPnD r2, 2x RB912UAG-5HPnD
On each of the RB (then v6.19 or 6.7) were the watchdog-reboot.
Sectors is tethered to a max of 10 clients.
I currently have 2x RB2011iL, 2x SXT G-5HPnD r2 on v6.20 and is watchdog-reboot
It is interesting that a few customers (nat, pppoe) on Lite5 with v6.19. The antenna does not restart to work properly.
I found our problem is that we create compact backups from routers every night with an external linux script, the script execute a command /export compat file=routername.backup when this command is executed, router sometime reboots with, software watchdog problem.
It is also possible to to cause it (not all the time) when I try to run this in winbox terminal window.
