I have a RB2011UiAS 2HnD and today i’ve upgraded the routerOS to 6.31
system automatically rebooted and everything seemed fine until my Wireless decided to constantly drop my laptop connection which was already in my ACL rule and had WPA2 / AES CCM enabled.
restarted the wifi adapter from the laptop re-entered the saved password towards the wifi connection, unfortunately it didn’t help a thing.
So I didn’t know for sure what was going on but I rebooted the router manually just to be sure.
Nope still nothing has changed.
So I checked the logs for more information during the connection setup.
got the following messages
@wlan1: connected
@wlan1: disconnected, unicast key exchange timeout
the time frame this happens is variable between 2~8 seconds where the ACL can see the connection but then the wlan immediately drops the connection for some reason I do not understand, as it worked before without problems…
Luckily i had settings back-up so i restored those… guess again nothing has changed i still can’t connect from wlan port.
so I resetted all the configurations and did everything all over again from scratch… in the end still the same…
wired works fine but wireless is just broken.
Any advise?
Kind Regards,
StaleDevil
