something will make me a grazy
hi everyone…i have this issue and need your explanation..
i have an wireless client ( 1km ) far of my mikrotik access point. the remote client use nanostation 5 ghz .he have very good link .see down…
but when i see his signal by winbox.. the mikrotike access point tell me other reading…see down
what does that mean!!!
Your client is receiving -52 signal from the AP.
Your AP is receiving -75 signal from the client.
When you’re logged into the client there is traffic to the client - higher cpq than when idle.
Try flood ping to the client while monitoring the signal/ccq at the AP and see if ccq increases.
Not knowing the topology, I’d guess the client needs an alignment or higher gain antenna to achieve a higher rx signal at the AP.
what do you mean by your saying (( idle ))
can not make a ping test between ubnt products and mikrotik products
what is the most important..rx signal or tx signal ??
No wireless traffic to/from client.
If the client device has an ip address… ping it.
Both are important. It is two way communication.
thank you for your replay.have you an e.mail to correspond with you.
No to the email. Sorry. It helps only one person.
Questions asked and answered in the forum helps many people.
ROS manual and Mikrotik wiki are excellent resources and can answer a great many questions asked in this forum.
