Sometime Internet fail Please hepl
i have Hotspot wifi create from mikrotik450g
eth1 — wan1 pppoe
eth2 — wan2 static
eth5 — loadbalance + hotspot
i use this script to make loag balance
#ether1=PPPoE
#ether2=192.168.1.123
#ether3=none
#ether4=none
#ether5=22.22.22.1 dhcp range 22.22.22.100-22.22.22.250
#loadbalance PCC 1 PPPoE+1 hotspot static Ratio 1:1
/interface pppoe-client
add disabled=no interface=ether1 name=pppoe-out1 password=456123 user=\
    7b8vm5ne74@truemes
add name=default-dhcp ranges=22.22.22.100-22.22.22.250
add address-pool=default-dhcp disabled=no interface=ether5 lease-time=2h \
    name=default
add address=192.168.1.123/24 interface=ether2 network=192.168.1.0
add address=22.22.22.1/24 comment="default configuration" interface=ether5 \
    network=22.22.22.0
/ip cloud
set ddns-enabled=yes
add address=22.22.22.0/24 comment="default configuration" dns-server=\
    22.22.22.1 gateway=22.22.22.1
set allow-remote-requests=yes cache-size=5000000KiB max-udp-packet-size=512 \
    servers=8.8.8.8,8.8.4.4
/ip dns static
add address=22.22.22.1 name=router
add chain=input comment="allow tcp port 81 Webfig" dst-port=81 in-interface=\
    ether2 protocol=tcp
add chain=input comment="allow tcp port 8291 WinBox" dst-port=8291 \
    in-interface=ether2 protocol=tcp
/ip firewall mangle
add chain=prerouting dst-address=22.22.22.0/24 in-interface=ether5
add chain=prerouting dst-address=192.168.1.0/24 in-interface=ether5
add action=mark-connection chain=prerouting dst-address-type=!local hotspot=\
    auth in-interface=ether5 new-connection-mark=ether1_conn \
    per-connection-classifier=both-addresses-and-ports:2/0
    auth in-interface=ether5 new-connection-mark=ether2_conn \
    per-connection-classifier=both-addresses-and-ports:2/1
add action=mark-routing chain=prerouting connection-mark=ether1_conn \
    in-interface=ether5 new-routing-mark=to_ether1
add action=mark-routing chain=prerouting connection-mark=ether2_conn \
    in-interface=ether5 new-routing-mark=to_ether2
add action=mark-routing chain=output connection-mark=ether1_conn \
add action=mark-routing chain=output connection-mark=ether2_conn \
add action=mark-connection chain=prerouting in-interface=pppoe-out1 \
add action=mark-connection chain=prerouting in-interface=ether2 \
add action=masquerade chain=srcnat out-interface=pppoe-out1
add action=masquerade chain=srcnat out-interface=ether2
add check-gateway=ping distance=1 gateway=192.168.1.1 routing-mark=to_ether2
add check-gateway=ping distance=1 gateway=pppoe-out1 routing-mark=to_wan1
add check-gateway=ping distance=2 gateway=192.168.1.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=0.0.0.0/0 port=81
set ssh disabled=yes
set api disabled=yes
set winbox address=0.0.0.0/0
set api-ssl disabled=yes
/system clock
set time-zone-autodetect=no time-zone-name=Asia/Bangkok
set [ find default-name=ether3 ] master-port=ether5
set [ find default-name=ether4 ] master-port=ether5
and it go good, no problem
but in last 3 year
my internet begin to fail many time per day, each day fail 3-20 minute
client cannot ping to gateway(ping 33.33.33.1 time out) cannot pin to every Internet, but can ping to another client (example:33.33.33.90) i test to ping NSA310 on the time internetfail it OK not timeout
it will fail in the time most people use
i try to connect mikrotik over 3g to ddns to see — can connect cpu 0-2% ip–hotspot–host empty
now it happen very frequently and long time
please help me
