SonicWall to Mikrotik Rb 1100ahx2
I wanted to create a site to site VPN using a mikrotik and a SonicWall tz400… Is this possible and if so what settings should I use on each device.
Thanks in advance!!
Sent from my XT1650 using Tapatalk
Suggestion
You can use L2TP IpSec
See if this material helps you https://mehmetkaplan.wordpress.com/2015/10/09/sonicwall-mikrotik-site-to-site-ipsec-vpn/
Leoservices thank you very much sir! That doc is perfect!!
