source routing
Hello
I have 3 networks:
192.168.100.0/24 (LAN1)
192.168.101.0/24 (LAN2)
192.168.102.0/24 (LAN3)
There is an interface 192.168.100.1/22 on the router. Also there are 3 ISP connected to the router.
The policy must be:
  • LAN1 uses 1st available connection
  • LAN2 always goes via 2nd ISP
  • LAN3 always goes via 3rd ISP
Configuration:
/ip firewall mangle
add action=mark-connection chain=forward in-interface=bridge-lan new-connection-mark=from_lan2 src-address=192.168.101.0/24
add action=mark-connection chain=forward in-interface=bridge-lan new-connection-mark=from_lan3 src-address=192.168.102.0/24
add action=mark-routing chain=prerouting connection-mark=from_lan2 in-interface=bridge-lan new-routing-mark=to_isp2
add action=mark-routing chain=prerouting connection-mark=from_lan3 in-interface=bridge-lan new-routing-mark=to_isp3
add action=masquerade chain=srcnat out-interface=ether8 src-address=192.168.100.0/22
add action=masquerade chain=srcnat out-interface=ether9 src-address=192.168.100.0/22
add action=masquerade chain=srcnat out-interface=ether10 src-address=192.168.100.0/22
add distance=1 gateway=109.86.229.254 routing-mark=to_isp1
add distance=1 gateway=37.229.191.254 routing-mark=to_isp2
add check-gateway=ping distance=1 gateway=8.8.8.8
add check-gateway=ping distance=2 gateway=8.8.4.4
add distance=1 dst-address=8.8.4.4/32 gateway=37.229.191.254 scope=10
add distance=1 dst-address=8.8.8.8/32 gateway=109.86.229.254 scope=10
ISP3 disconnected at the moment (there is no route to it)
The problem that clients from LAN2 (192.168.101.0/24) do not have access to Inet. Bit if I disconnect cable connected to ISP1, Inet becomes available for LAN1 and LAN2.
/ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
 0 A S  0.0.0.0/0                          109.86.229.254            1
 1 A S  0.0.0.0/0                          37.229.191.254            1
 2 A S  0.0.0.0/0                          8.8.8.8                   1
 3   S  0.0.0.0/0                          8.8.4.4                   2
 4 A S  8.8.4.4/32                         37.229.191.254            1
 5 A S  8.8.8.8/32                         109.86.229.254            1
 6 ADC  37.229.128.0/18    37.229.156.88   ether9                    0
 7 ADC  109.86.229.0/24    109.86.229.211  ether8                    0
 8 ADC  192.168.100.0/22   192.168.100.1   bridge-lan                0
Any ideas what it may be?
Thanks!
Verify that ping actually might still be working which would cause the expected action to fail.
You are right. Ping does work.
It is final configuration with 3rd connection but it still does not work as expected
add distance=1 gateway=192.168.252.1 routing-mark=to_isp3
add distance=3 gateway=192.168.252.1
Have you read this?
http://mum.mikrotik.com/presentations/US12/tomas.pdf
I have read the doc quickly. Thanks.
Do you mean to use different routing tables? main for directly connected networks:
and create other table for dgw:
I have replaced
by
add action=mark-connection chain=prerouting in-interface=bridge-lan new-connection-mark=from_lan2 src-address=192.168.101.0/24
add action=mark-connection chain=prerouting in-interface=bridge-lan new-connection-mark=from_lan3 src-address=192.168.102.0/24
(changed forward chain to prerouting chain) in mangletable and everyting seems fine
Thanks all for help!
Awesome!
Here is a cool link about chains that I’m reading very slowly. I’m finding it helpful in addition to the official packet flow diagrams MikroTik provides.
Thanks for the useful links.
I know about packet flow in iptables and use this diagram but unfortunately I forget some things periodically like this time.
But official MikroTik packet flow diagram is awesome! Thank you very much for it!
