SPAN PORT configuration
Can someone help me to conduct SPAN PORT on Mikrotik switch ?
I found this one: “/interface ethernet switch set numbers=0 mirror-source=ether2 mirror-target=ether5”, but not understand much about it.
And when I tried on my switch, it returned “no such item”. Thanks
Port mirroring as described in mikrotik manual works for me.
well, it depends on the model, and also the number 0 which is a reference to an item to be configured is only relevant after a previous print command
so give more details about the model, or even better follow the suggestion in my automatic signature.
