Hello friends.
I have configured in my home network, that all users in network use OPEN DNS 8.8.8.8
which i did through DHCP Server.
To Block bad sites for specific user i want to use filtered dns 208.67.222.222 and 208.67.220.220.
So, Is there a way to restrict specific users to use the DNS i specified in DHCP Server.
I mean Even if they assign DNS manually my preferred DNS in Mikrotik should override.
Many Thanks
you can use NAT for this, but first you need add client ip in address list if you want add too filtered dns, next you can use this rule
add action=dst-nat chain=dstnat comment=OpenDNS dst-port=53,5353 protocol=udp \
src-address-list=opendns to-addresses=208.67.222.222 to-ports=5353
src-address-list=opendns to-addresses=208.67.220.220 to-ports=5353
make sure that rule in the top after masquerade rule, and dont forget add client ip on opendns address list
