Specific IP set as DMZ
On a WRT54GL running DD-WRT you get an option to assign a single IP as a machine in the DMZ.
How can I do this in RouterOS?
LAN IP Range is 192.168.0.0/24
Machine that I want to specify is in a range 192.168.10.0/24 (connecting through another interface)
Regards
Chris
This sounds like a destination NAT. You need to NAT all new connections to the external interface across to the internal IP of the DMZ machine.
Regards
Andrew
