specify bandwidth
my max limit(bandwidth)=256/2048 kbps,i have 20 ip adress
i want specify bandwith for each ip address
for example
32/128 kbps for this ip 192.168.0.12
64/256 kbps for this ip 192.168.0.17 and so on
my email (paiamy_mn@yahoo.com)
i need help you please help me i you can[/b]
it’s easily u can set it through userman by limiting per user Tx and Rx…try it!! :slight_smile:
thanks for great works, MT team :slight_smile:
thank you for answer me
but i have 256/2048 kbps
and i have 17 ip adress i want specify bandwith for each ip
You need to create separate user for each IP and use required ‘rate-limit’ configuration.
