Hi!
I have a problem make MT router do connection from some specified LAN address to WAN using other provider given IP address than other addresses using to connect WAN.
So Providers given adresses: XX.XX.XX.100; XX.XX.XX.101
Configuration:
RouterOS v3.28
LAN 192.168.2.X
WAN XX.XX.XX.100
Using NAT/Masquerade
[admin@MikroTik] /ip address> pri
# ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.2.1/24 192.168.2.0 192.168.2.255 ether2
1 XX.XX.XX.100/24 XX.XX.XX.0 XX.XX.XX.255 ether1
[admin@MikroTik] /ip route> pri
# DST-ADDRESS PREF-SRC GATEWAY-STATE GATEWAY DISTANCE INTERFACE
0 A S 0.0.0.0/0 reachable XX.XX.XX.1 1 ether1
1 ADC 192.168.2.0/24 192.168.2.1 0 ether2
2 ADC XX.XX.XX.0/24 XX.XX.XX.100 0 ether1
[admin@MikroTik] /ip firewall nat> pri
0 chain=srcnat action=masquerade out-interface=ether1
Is any solution configuration from LAN’s IP 192.168.2.33 access internet with IP XX.XX.XX.101
while other LAN’s adresses still - XX.XX.XX.100 ?
Using NAT Netmap? What i need to change in Ether1 IP address? Something in IP routing?
