Specs of RB411UAHR Wireless card
I would like to know what is the Power of the builted in wireless card that comes in the RB411UAHR?
I was checking on the site and find 20db@11Mbps b and 15db@54Mbps g, but I’m not sure if that is the same for example as the R52 that has 19dBm…I am basically looking the ammount of dBm that the card has
Thanks for your attention and responses
but you quoted yourself, 20db@11Mbps b and 15db@54Mbps g
what else are you looking for :slight_smile: ?
all wireless cards have different TX power at different datarates.
Thanks Normis,
I wasn’t sure of that…like other cards it just appears 25dBm…I thought that was for both ranges
if one number is mentioned, it is the maximum possilble
