Spectral scan chain 1
How I can do spectral scan in chain 1 in RB’s MIMO.
I enable chains 0,1 and give me scan
Only enable chain 1 in mk. I try and I don’ see the scan.
Only work in chain 0?
it’s possible to scan chain 1?
thks.
disable chain 0 then perform a scan
Thanks for reply.
I only enable the chain 1 and I see a constant noise -90dBm, although I know that is not so.
I test dude 3.6
Someone tried enabling only the chain 1 with the dude
Thanks,
