Spectrum scan of 2,4 band
brings crash of RBs unexpectadly.. Tested on RB600 and Allix platform. Platform restarts, no error listed in log..
specrtum scan is only supported on a few wireless cards
http://wiki.mikrotik.com/wiki/Manual:Spectrum_analyzer
Everything correct, R52N used (purely :slight_smile: ) Just for hint.. 5GHz scan has no such attitude.
Which RouterOS version and what wireless settings, please post.
It is 5B5 now on Alixes (more stable seems). Setting regular Nstreme dual.
Nstreme dual setting
0 R name=“nstreme1” mtu=1500 l2mtu=2290 mac-address=00:0C:42:61:B3:77
arp=enabled disable-running-check=no tx-radio=TX rx-radio=RX
remote-mac=00:0C:42:61:69:61 tx-band=(unknown) tx-channel-width=20mhz
tx-frequency=2342 rx-band=(unknown) rx-channel-width=20mhz
rx-frequency=2447 disable-csma=yes rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
ht-rates=1,2,3,4,5,6,7,8 ht-guard-interval=both ht-channel-width=20mhz
ht-streams=single framer-policy=exact-size framer-limit=4000
cards:
0 name=“RX” mtu=1500 mac-address=00:0C:42:61:B3:77 arp=enabled
interface-type=Atheros 11N mode=nstreme-dual-slave ssid=“Multipoint1”
frequency=2192 band=2ghz-b/g/n channel-width=20mhz scan-list=default
wireless-protocol=unspecified wds-mode=disabled wds-default-bridge=none
wds-ignore-ssid=no default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
security-profile=default compression=no
1 name=“TX” mtu=1500 mac-address=00:0C:42:61:C8:A1 arp=enabled
frequency=2412 band=2ghz-b/g/n channel-width=20mhz scan-list=default
Nstreme given to bridge.. thats it.. But it seem doesnt matter if Nstreme used or not.. May be somebody sugest 2.4 is not band to make scan :slight_smile:.. But, this is board for transvertors, so the freqs are like intermediate frequencies, and are not used outside the system. This way it serves as spectrum analyzer on 10GHz :slight_smile:
