I am setting up a large high school with PtP connections to all the builbings and I just started testing the 2.6Ghz P4 main AP which has 2 SR2 cards now but I am going to replace them with 4 CM9 cards. The client ends are rb532s with CM9 cards.
The thing that is making my crazy is that all I can get from the setup is 15mbps TCP. Thats testing from two 3.2Ghz PC on each side of the link.
I am using AP-bridge and the two wireless cards and ether1 are in a bridge. On the client rb532 I am running station-wds and bridgeing it to ether1.
I ran the tests and only got the 15 mbps speed so I tryed the same test on a 2.5Ghz pc as client and got the same speed.
Any idea why it’s so slow?
This could be because of the data rates, link quality, distance, etc…
ok, here’s what I have.
PC#1 3.2ghz PC with FTP server and MT Bandwidth Test Server.
PC#2 2Ghz Laptop with FTP Client and MT Bandwidth Test server.
RB#1 RB532 with SR5 miniPCI card and OS ver.2.9.24, AP-bridge WDS, Ether1 and Wlan1 in Bridge1
RB#2 RB532 with SR5 miniPCI card and OS ver.2.9.24, Station-WDS, ether1 and Wlan1 in Bridge1
Tests are running on the PCs.
The two RBs are sitting next to each other with no antennas.
I have PC#1 connected to RB#1 via ethernet, RB#1 wirelessly connects to RB#2, RB#2 connects to PC#2 via ethernet.
The Signal is -64 and the connection speed is 54mbps.
I have ran the BWT and it only gets 13.2 TCP rx or tx, but it gets 27mbps UDP.
The FTP client shows 2000kbps on transfers.
What’s the problem here?
update:
I have added antennas and I moved the things 6 feet and 20 feet away from each other. It has made no difference.
Still only 13 to 14 mbps TCP one way.
I tried the SR5s and the NMP8602s.
I have ordered more CM9s and R52s for testing.
Has anyone else had any speed issues?
I am routing it now and I get 21mbps from 532 to 532 with BW tester.
BUT if I run the BW tester on the two PCs I only get 12 to 13mbps.
WT@#$%& ?
Do you do the bwt in both directions?
see the cpu load on the 532
when you generate packages it is on 100% the load
do the bwt and see if ther is a broblem in your lan ![]()
turn off connection-tracking?
remove ap-bridge out of bridge (you need only bridge wds + ether1) and set it in ‘bridge’ mode.
SR5’s…those are stronger than 65 mw cards? then they get hotter than the 65 mw cards..
limit supported-rates to 6mbps through 36mbps. set basic rate to 18 mbits only. (do on both sides)
You mean change the AP-Bridge to Bridge? And how should I set the client side?
I will try these things and let ya know how it goes.
PS Thanks for the help. It’s greatly appreciated.
Connection tracking is off.
RB532 #1
[admin@MikroTik] > interface wireless print
0 X name=“wlan1” mtu=1500 mac-address=00:15:6D:50:0A:88 arp=enabled
disable-running-check=no interface-type=Atheros AR5213
radio-name=“00156D500A88” mode=station ssid=“MikroTik” area=“”
frequency-mode=manual-txpower country=no_country_set antenna-gain=0
frequency=2412 band=2.4ghz-b scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=default
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
compression=no allow-sharedkey=no
1 R name=“wlan2” mtu=1500 mac-address=00:15:6D:51:09:B2 arp=enabled
radio-name=“00156D5109B2” mode=station-wds ssid=“MikroTik” area=“”
frequency=5180 band=5ghz scan-list=default rate-set=configured
54Mbps
basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic
[admin@MikroTik] > interface bridge print
0 R name=“bridge1” mtu=1500 arp=enabled mac-address=00:0C:42:04:EB:06 stp=no priority=32768
ageing-time=5m forward-delay=15s garbage-collection-interval=5s hello-time=2s
max-message-age=20s
RB532 #2
0 X name=“wlan1” mtu=1500 mac-address=00:15:6D:50:0A:8D arp=enabled
radio-name=“00156D500A8D” mode=station ssid=“MikroTik” area=“”
54Mbps
1 R name=“wlan2” mtu=1500 mac-address=00:15:6D:51:09:AA arp=enabled
radio-name=“00156D5109AA” mode=ap-bridge ssid=“MikroTik” area=“”
54Mbps
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=dynamic
wds-default-bridge=bridge1 wds-default-cost=100 wds-cost-range=50-150
0 R name=“bridge1” mtu=1500 arp=enabled mac-address=00:0C:42:04:EA:FD stp=no
priority=32768 ageing-time=5m forward-delay=15s garbage-collection-interval=5s
hello-time=2s max-message-age=20s
Only getting 14Mbps tcp one way and 7.7Mbps both ways.
