I have some speed issue with my mikrotik.
Here are the speed test result.
ont 2.5Gbps → dac 10gbps → ccr2004 → sfp 2.5gpbs
speed test down 1,7Gbps up 550 Mbps
ont 2.5Gbps → dac 1gbps → ccr2004 → sfp 2.5gpbs
speed test down 950 Mbps up 550 Mbps
ont 2.5Gbps → dac 1gbps → ccr2004 → sfp 1gpbs
speed test down 950 Mbps up 550Mbps
ont 2.5Gbps → dac 10gbps → ccr2004 → sfp 1gpbs
speed test down 600Mbps up 550Mbps
My RouterOs is 6.48.
My config is :
# jan/28/2021 09:46:50 by RouterOS 6.48
# software id = NKWZ-YNTM
# model = CCR2004-1G-12S+2XS
# serial number = D4F00CCB4DA8
add name=bridge_ftth_cos
set [ find default-name=sfp-sfpplus12 ] advertise=1000M-half,1000M-full \
auto-negotiation=no rx-flow-control=on speed=10Gbps tx-flow-control=on
/interface vlan
add interface=sfp-sfpplus12 \
loop-protect-disable-time=0s loop-protect-send-interval=1s name=\
vl_832-ftth vlan-id=832
/ip dhcp-client option
add code=77 name=userclass value="replaced"
add code=60 name=vendor-class-identifier value="replaced"
add code=90 name=authsend value="replaced"
/interface bridge filter
add action=set-priority chain=output dst-port=67 ip-protocol=udp limit=1,5 \
log=yes log-prefix="Set CoS6 on DHCP request" mac-protocol=ip \
new-priority=6 out-interface=vl_832-ftth packet-type=host passthrough=yes
add bridge=bridge_ftth_cos interface=vl_832-ftth
/ip dhcp-client
add comment=FTTH default-route-distance=2 dhcp-options=\
hostname,clientid,authsend,userclass,vendor-class-identifier disabled=no \
interface=bridge_ftth_cos
add action=fasttrack-connection chain=forward connection-state=\
established,related
add action=accept chain=forward connection-state=established,related
add action=drop chain=forward dst-address=10.0.0.0/8 src-address=\
172.16.0.0/25
add action=drop chain=forward dst-address=172.16.0.128/25 src-address=\
172.16.0.0/25
add action=drop chain=input connection-state=!established,related \
in-interface=bridge_ftth_cos
add action=masquerade chain=srcnat comment=FTTH out-interface=bridge_ftth_cos
/ip service
set telnet disabled=yes
set www disabled=yes
/system clock
set time-zone-name=Europe/Paris
/tool mac-server
I try to replace the dac by an optic link, same issue
I also try to modify queue to ethernet, same.
