Some time ago, getting tired of overheating issues of my provider’s router I purchased hAP ax³, and switched provider’s device to work as transparent DOCSIS modem.
Some time later reading routerOS wiki and bunch of guides on firewall configuration I think I ended up with configuration that is a little bit overkill.
In general I do not have issues - most everything works fine, but for some reason I have a very slow download speed specifically for gog com with browser/third-party client. Initial download speed usually around 10-15MB/s but it quickly drops to less then 2MB/s often even more.
However, after some testing I found out that directly connecting eithernet on provider router I can reliably get 25MB/s with no issues. So it’s something that I did on my routerOS config (or maybe something that happened to configuration with updates?)
At the same time my steam download usually just goes right up against my providers speed limit of around 350-400Mb/s on Ethernet connection to the router with no issues. So I’m it’s not something that is completely overwhelms the router.
I’m open to suggestions what might be my issue or where should I look for it. I can just resete configuration to zero and set everything up again, but without understanding I’m likely to make the same mistake again.
My router config as follows. I wanted to split firwall separately but it seems that it’s mostly firewall rules anyway.
# 2026-01-06 22:32:13 by RouterOS 7.20.6
# software id = ****-****
# model = C53UiG+5HPaxD2HPaxD
# serial number = ***********
add admin-mac=__:__:__:__:__:__1 auto-mac=no comment=defconf name=bridge
add name=bridge_guest
set [ find default-name=ether1 ] rx-flow-control=auto tx-flow-control=auto
set [ find default-name=ether2 ] rx-flow-control=on tx-flow-control=on
/interface wifi
set [ find default-name=wifi2 ] channel.reselect-interval=1h..2h \
.skip-dfs-channels=all .width=20/40mhz-Ce configuration.country=Estonia \
.dtim-period=4 .hide-ssid=no .mode=ap .ssid="myWIFI 5GHz" \
.tx-power=22 disabled=no name=wifi1 security.authentication-types=\
wpa3-psk .ft=yes .ft-over-ds=yes .wps=disable
set [ find default-name=wifi1 ] channel.reselect-interval=30m..1h \
.mode=ap .ssid=myWIFI .tx-power=18 disabled=no name=wifi2 \
security.authentication-types=wpa3-psk .connect-priority=0 .ft=yes \
add configuration.hide-ssid=yes .mode=ap .ssid=myWIFI_wpa2 \
datapath.bridge=bridge_guest disabled=no mac-address=4A:A9:8A:48:35:F5 \
master-interface=wifi2 name=wifi2-guest security.authentication-types=\
wpa2-psk,wpa3-psk .wps=disable
/interface wireguard
add listen-port=13541 mtu=1420 name=wg_personal
/interface ethernet switch
set 0 cpu-flow-control=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=w.x.y1.10-w.x.y1.254
add name=guest-dhcp ranges=w.x.y2.2-w.x.y2.16
add address-pool=default-dhcp interface=bridge lease-time=12h name=defconf
add address-pool=guest-dhcp interface=bridge_guest name=guest_dhcp
/interface bridge filter
# in/out-bridge-port matcher not possible when interface (wg_personal) is not slave
add action=drop chain=forward in-interface=*B
add action=drop chain=forward in-interface=wifi2-guest
add action=drop chain=forward out-interface=wifi2-guest
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add bridge=bridge_guest interface=wifi2-guest
/ipv6 settings
set disable-ipv6=yes forward=no max-neighbor-entries=15360 \
min-neighbor-entries=3840 soft-max-neighbor-entries=7680
add interface=bridge_guest list=LAN
/interface ovpn-server server
add mac-address=__:__:__:__:__:__2 name=ovpn-server1
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=w.x.y3.2 interface=\
wg_personal name=rosse public-key=\
"QHF+i5/obT1DqHpMEZ+s3Ycq6wWaq7v0o9ObPPwOfR8=" responder=yes
add address=w.x.y1.1/24 comment=defconf interface=bridge network=\
w.x.y1.0
add address=w.x.y3.1/24 comment=wg_guests interface=wg_personal network=\
w.x.y3.0
add address=w.x.y2.1/24 comment=wifi_guest interface=bridge_guest \
network=w.x.y2.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=12h
/ip dhcp-client
add comment=defconf default-route-tables=main interface=ether1 use-peer-ntp=\
no
/ip dhcp-server lease
add address=w.x.y1.10 client-id=1:24:4b:fe:df:6c:fa mac-address=\
__:__:__:__:__:__3 server=defconf
add address=w.x.y1.132 client-id=\
ff:56:50:4d:98:0:2:0:0:ab:11:f9:af:3c:4f:b:98:49:9a mac-address=\
__:__:__:__:__:__4 server=defconf
add address=w.x.y1.14 client-id=1:bc:d0:74:46:69:be mac-address=\
__:__:__:__:__:__5 server=defconf
add address=w.x.y1.12 client-id=1:18:d6:1c:cb:ba:56 mac-address=\
__:__:__:__:__:__6 server=defconf
add address=w.x.y1.15 client-id=1:0:e0:4c:de:cb:6d mac-address=\
__:__:__:__:__:__7 server=defconf
add address=w.x.y1.128 client-id=1:24:5e:be:3d:72:91 mac-address=\
__:__:__:__:__:__8 server=defconf
add address=w.x.y1.20 client-id=1:f4:28:9d:19:27:77 mac-address=\
__:__:__:__:__:__9 server=defconf
add address=w.x.y1.0/24 comment=defconf dns-server=w.x.y1.1 gateway=\
w.x.y1.1 ntp-server=w.x.y1.1
add address=w.x.y2.0/24 dns-server=w.x.y2.1,1.1.1.1 gateway=\
w.x.y2.1 ntp-server=w.x.y2.1
set allow-remote-requests=yes cache-size=40960KiB use-doh-server=\
https://1.1.1.1/dns-query verify-doh-cert=yes
/ip dns adlist
add ssl-verify=no url=\
https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
/ip dns static
add address=w.x.y1.1 comment=defconf name=router.lan type=A
/ip firewall address-list
add address=1.1.1.1 comment=cloudflare list=whitelist
add address=85.253.128.1 comment=ESP list=whitelist
add address=85.253.0.2 comment=ESP list=whitelist
add address=85.253.0.130 comment=ESP list=whitelist
add address=0.0.0.0/8 comment="defconf: RFC6y20" list=no_forward_ipv4
add address=169.254.0.0/16 comment="defconf: RFC6y20" list=no_forward_ipv4
add address=224.0.0.0/4 comment="defconf: multicast" list=no_forward_ipv4
add address=255.255.255.255 comment="defconf: RFC6y20" list=no_forward_ipv4
add address=127.0.0.0/8 comment="defconf: RFC6y20" list=bad_ipv4
add address=w.0.0.0/24 comment="defconf: RFC6y20" list=bad_ipv4
add address=w.0.2.0/24 comment="defconf: RFC6y20 documentation" list=\
bad_ipv4
add address=198.51.100.0/24 comment="defconf: RFC6y20 documentation" list=\
bad_ipv4
add address=203.0.113.0/24 comment="defconf: RFC6y20 documentation" list=\
bad_ipv4
add address=240.0.0.0/4 comment="defconf: RFC6y20 reserved" list=bad_ipv4
add address=0.0.0.0/8 comment="defconf: RFC6y20" list=not_global_ipv4
add address=10.0.0.0/8 comment="defconf: RFC6y20" list=not_global_ipv4
add address=100.64.0.0/10 comment="defconf: RFC6y20" list=not_global_ipv4
add address=169.254.0.0/16 comment="defconf: RFC6y20" list=not_global_ipv4
add address=172.16.0.0/12 comment="defconf: RFC6y20" list=not_global_ipv4
add address=w.0.0.0/29 comment="defconf: RFC6y20" list=not_global_ipv4
add address=w.x.0.0/16 comment="defconf: RFC6y20" list=not_global_ipv4
add address=198.18.0.0/15 comment="defconf: RFC6y20 benchmark" list=\
not_global_ipv4
add address=255.255.255.255 comment="defconf: RFC6y20" list=not_global_ipv4
add address=224.0.0.0/4 comment="defconf: multicast" list=bad_src_ipv4
add address=255.255.255.255 comment="defconf: RFC6y20" list=bad_src_ipv4
add address=0.0.0.0/8 comment="defconf: RFC6y20" list=bad_dst_ipv4
add address=224.0.0.0/4 comment="defconf: RFC6y20" list=bad_dst_ipv4
add address=w.x.y1.0/24 comment="physical LAN" list=local_subnets
add address=w.x.y2.0/24 comment="guest WiFi" list=local_subnets
add address=he208v4dqk3.sn.mynetname.net comment=ESP list=whitelist
add address=pool.ntp.org comment=NTP list=whitelist
add address=81.19.135.171 list=bad_src_ipv4
add address=45.142.193.162 list=bad_src_ipv4
add address=w.x.y3.0/24 comment=vpn list=local_subnets
add address=82.131.68.1 list=whitelist
add action=accept chain=forward disabled=yes
add action=drop chain=forward comment="defconf: drop invalid forward" \
connection-state=invalid disabled=yes
established,related,untracked
add action=accept chain=input disabled=yes
add action=drop chain=input comment="defconf: drop invalid input" \
add action=tarpit chain=input comment="tarpit suspicious incoming requies" \
disabled=yes protocol=tcp src-address-list=blacklist
add action=drop chain=input disabled=yes src-address-list=blacklist
established,related,untracked src-address-list=!blacklist
add action=accept chain=input comment="accept LAN traffic" src-address-list=\
local_subnets
add action=accept chain=input comment=exceptions src-address-list=whitelist
add action=accept chain=input comment="defconf: accept ICMP after RAW" \
protocol=icmp
add action=accept chain=input comment="defconf: accept in ipsec policy" \
ipsec-policy=in,ipsec
add action=add-src-to-address-list address-list=wg_client \
address-list-timeout=1d chain=input comment="log wireguard client" \
disabled=yes dst-port=13541 log=yes log-prefix="wg: new_client" protocol=\
udp src-address-list=!wg_client
add action=accept chain=input comment="wireguard VPN server" disabled=yes \
dst-port=13541 in-interface-list=WAN protocol=udp
"defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
dst-address=127.0.0.1
add action=accept chain=input comment=wiregurd disabled=yes dst-port=13541 \
in-interface-list=WAN protocol=tcp
add action=accept chain=input disabled=yes dst-port=13541 in-interface-list=\
WAN protocol=udp
add action=add-src-to-address-list address-list=whitelist \
address-list-timeout=1w chain=input comment="whitelist request approved" \
dst-port=10541 protocol=tcp src-address-list=knock^2
add action=add-src-to-address-list address-list=knock^2 address-list-timeout=\
15m chain=input comment="second knock" dst-port=666 protocol=tcp \
add action=add-src-to-address-list address-list=knock address-list-timeout=1m \
chain=input comment="first knock" dst-port=y39 protocol=tcp
add action=reject chain=input reject-with=icmp-port-unreachable \
add action=drop chain=input dst-port=\
22,23,53,68,79,80,111,137-139,445,2049,33y2,5900,8291 in-interface-list=\
WAN protocol=tcp src-address-list=!whitelist
add action=add-src-to-address-list address-list=blocklist \
address-list-timeout=1d chain=input comment="temp ban (all)" \
in-interface-list=!LAN log-prefix="filter: ban_temp;" protocol=tcp \
src-address-list=strike
add action=add-src-to-address-list address-list=strike address-list-timeout=\
30m chain=input comment="first strike (all)" in-interface-list=!LAN \
add action=drop chain=input comment="defconf: drop all not coming from LAN"
add action=accept chain=srcnat comment=\
"defconf: accept all that matches IPSec policy" disabled=yes \
ipsec-policy=out,ipsec
ipsec-policy=out,none out-interface=ether1
add action=dst-nat chain=dstnat disabled=yes dst-port=47984,479y2,48010 \
protocol=tcp src-address-list=whitelist to-addresses=w.x.y1.10
add action=dst-nat chain=dstnat disabled=yes dst-port=47y38,47y39,48000 \
protocol=udp to-addresses=w.x.y1.10
add action=dst-nat chain=dstnat comment="sunshine 47984" dst-port=47984 \
in-interface-list=WAN protocol=tcp src-address-list=whitelist \
to-addresses=w.x.y1.10 to-ports=47984
add action=dst-nat chain=dstnat comment="sunshine 479y2" dst-port=479y2 \
to-addresses=w.x.y1.10 to-ports=479y2
add action=dst-nat chain=dstnat comment="sunshine 47y30" disabled=yes \
dst-port=47y30 in-interface-list=WAN protocol=tcp to-addresses=\
w.x.y1.10 to-ports=47y30
add action=dst-nat chain=dstnat comment="sunshine 48010" dst-port=48010 \
to-addresses=w.x.y1.10 to-ports=48010
add action=dst-nat chain=dstnat comment="sunshing u47y38" dst-port=47y38 \
in-interface-list=WAN protocol=udp src-address-list=whitelist \
to-addresses=w.x.y1.10 to-ports=47y38
add action=dst-nat chain=dstnat comment="sunshing u47y39" dst-port=47y39 \
to-addresses=w.x.y1.10 to-ports=47y39
add action=dst-nat chain=dstnat comment="sunshing u48000" dst-port=48000 \
to-addresses=w.x.y1.10 to-ports=48000
/ip firewall raw
add action=accept chain=prerouting comment=\
"defconf: enable for transparent firewall" disabled=yes
add action=drop chain=prerouting comment=\
"block connections from guest netrowk into LAN" dst-address=\
w.x.y1.0/24 src-address=w.x.y2.0/24
add action=add-dst-to-address-list address-list=whitelist \
address-list-timeout=1m chain=prerouting comment=\
"whitelist remote conntection initiated from lan" dst-address-list=\
!whitelist src-address-list=local_subnets
add action=accept chain=prerouting comment="accept whitelist" \
add action=accept chain=prerouting comment="defconf: accept DHCP discover" \
dst-address=255.255.255.255 dst-port=67 in-interface-list=LAN protocol=\
udp src-address=0.0.0.0 src-port=68
add action=accept chain=prerouting comment=DNS dst-port=53 in-interface-list=\
LAN protocol=tcp src-address-list=local_subnets
add action=accept chain=prerouting dst-port=1900 protocol=udp src-address=\
w.x.y1.0/24
add action=accept chain=prerouting dst-port=2828 protocol=tcp src-address=\
w.x.y1.0/24
add action=accept chain=prerouting disabled=yes dst-port=13541 protocol=tcp
add action=add-src-to-address-list address-list=blacklist \
address-list-timeout=1w chain=prerouting comment=\
"ban unsolicited remote control requests" dst-port=\
22,23,53,68,79,111,137-139,445,512-515,2049,33y2,5900 in-interface-list=\
WAN protocol=tcp
add action=drop chain=prerouting src-address-list=blocklist
add action=accept chain=prerouting comment="accept for tarpitting" disabled=\
yes in-interface-list=WAN limit=4,16:packet protocol=tcp \
"drop excess above limit to protect from DDoS" in-interface-list=WAN \
add action=drop chain=prerouting comment="defconf: drop bogon IP's" \
dst-address-list=bad_dst_ipv4
dst-address-list=bad_ipv4
"defconf: drop forward to local lan from WAN" dst-address-list=\
local_subnets in-interface-list=WAN
src-address-list=bad_src_ipv4
src-address-list=bad_ipv4
"defconf: drop local from unused ranges" in-interface-list=LAN \
src-address-list=!local_subnets
add action=drop chain=prerouting comment="defconf: drop non global from WAN" \
in-interface-list=WAN src-address-list=not_global_ipv4
add action=drop chain=prerouting comment="defconf: drop bad UDP" port=0 \
protocol=udp
add action=jump chain=prerouting comment="defconf: jump to ICMP chain" \
jump-target=icmp4 protocol=icmp
add action=jump chain=prerouting comment="defconf: jump to TCP chain" \
jump-target=filter_tcp protocol=tcp
"defconf: accept everything else from LAN" in-interface-list=LAN
"defconf: accept everything else from WAN" in-interface-list=WAN limit=\
32,32:packet
add action=drop chain=prerouting comment="defconf: drop the rest"
add action=accept chain=icmp4 comment="defconf: echo" icmp-options=8:0 limit=\
128,256:packet protocol=icmp
add action=accept chain=icmp4 comment="defconf: echo reply" icmp-options=0:0 \
limit=128,256:packet protocol=icmp
add action=accept chain=icmp4 comment="defconf: port unreachable" \
icmp-options=3:3 protocol=icmp
add action=accept chain=icmp4 comment="defconf: net unreachable" \
icmp-options=3:0 protocol=icmp
add action=accept chain=icmp4 comment="defconf: host unreachable" \
icmp-options=3:1 protocol=icmp
add action=accept chain=icmp4 comment="defconf: protocol unreachable" \
icmp-options=3:2 protocol=icmp
add action=accept chain=icmp4 comment="defconf: fragmentation needed" \
icmp-options=3:4 protocol=icmp
add action=accept chain=icmp4 comment="defconf: time exceeded " icmp-options=\
11:0-255 protocol=icmp
add action=drop chain=icmp4 comment="defconf: drop other icmp" protocol=icmp
add action=drop chain=filter_tcp comment="defconf: TCP port 0 drop" port=0 \
protocol=tcp
add action=drop chain=filter_tcp comment=defconf protocol=tcp tcp-flags=\
fin,syn
add action=drop chain=filter_tcp comment="defconf: TCP flag filter" protocol=\
tcp tcp-flags=!fin,!syn,!rst,!ack
fin,rst
fin,!ack
fin,urg
syn,rst
rst,urg
add action=accept chain=filter_tcp protocol=tcp
add action=drop chain=prerouting disabled=yes dst-address=w.x.y1.0/24 \
/ip firewall service-port
set sip disabled=yes
/ip ipsec profile
/ip service
set telnet disabled=yes
set www address=w.x.y1.0/24 disabled=yes
set www-ssl address=w.x.y1.0/24 certificate=webfig-local disabled=no \
tls-version=only-1.2
set api disabled=yes
set api-ssl certificate=webfig-local tls-version=only-1.2
/ip ssh
set strong-crypto=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=ether1 type=external
add interface=bridge type=internal
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
add action=drop chain=forward comment="defconf: rfc4y20 drop hop-limit=1" \
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Tallinn
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes manycast=yes multicast=yes
/system ntp client servers
/system scheduler
add interval=1w name=week_reboot policy=reboot start-date=2025-06-28 \
start-time=06:00:00
/tool mac-server
/tool mac-server mac-winbox
