I’m not an expert when it comes to MikroTik, and I’m having a problem with my routeros.
I’ve got a single ip and I am using nat for a few pc’s on my router, I’'ve set up a masquerade in the firewall nat section and everything is working fine but I’m getting poor download speeds and great upload speeds.
I’ve got a symetric 2mb connection and I’ve checked that it’s working before it hits the router.
I’ve reset everything and started again from scratch, have I missed something?
Yes i have same issues..
Could you test ftp connection to bandwith?
Because its look like web connection limited 150kb.. (Per connection)
If you try to use Download accelerator. Every connection limited same.
If its working at all then your configured right … there is probably an MTU mismatch, or a queue upstream from you. Again, you said things are working they are just slow, so I would think the NAT/firewall rules are working as they should.
Take a packet capture and see if you are finding lots of retransmits - also check to make sure your MTU is what it should be. Also check to make sure ICMP is not being blocked.
I have similar problem. Double checked everything.
Everything seem working correctly except
poor connection speed especially to web sides.
This issue may not related MTU.
I want to share my experience :
Hotspot user -----> Mikrotik --------->Internet
Hotspot(PPPoE) user that behind mikrotik router which is uses src-nat have poor connection quality either limited or unlimited BW.
Upload speed dramaticly 4 or 5 times faster than download speed(web connection)
When i tried to download something from ftp server speed
goes to near saturing internet lines. My speed access up to 1.4 Mbit. ( All same condutions)
Changing client machine, switch, browser etc. haven’t change any result.
Finally another strande behaviour that when i tried flasget like program download speed going to near ftp speed result.
Its looks like something limiting per connection to particiular speed.. However i haven’t set anything like PCQ.
I investigate or firewall and queue rules however i haven’t found anything that related this.
So i wonder if glen66 have same problems! If he/she have
may be we found a bug!
