Hi
I have read multiple threads about people trying to throttle an EoiP connection. The only thread that seemed to have the right direction was suggesting to “use IP FIREWALL” on the bridge interface settings.
This made sense as when you create an L2 bridge none of the traffic is passing through the routers firewall and you are therefore unable to mangle and QoS the traffic.
I need to set a 5Mbps limit to an EoiP tunnel and even though I have selected for the bridge settings to “Use IP Firewall” I cannot manage to Mangle and limit the traffic.
Bridge
interface bridge pr
0 R name="LAN" mtu=1500 l2mtu=1598 arp=enabled mac-address=02:CF:80:58:BD:32
protocol-mode=rstp priority=0x8000 auto-mac=yes
admin-mac=00:00:00:00:00:00 max-message-age=20s forward-delay=15s
transmit-hold-count=6 ageing-time=5m
Bridge Ports
interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
# INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 eoip-fraserjetHO LAN 0x80 10 none
1 ether2-UserSwitch LAN 0x80 10 none
Bridge Settings
interface bridge settings pr
use-ip-firewall: yes
use-ip-firewall-for-vlan: no
use-ip-firewall-for-pppoe: no
allow-fast-path: ye
IP Firewall Mangle (I think this might be incorrect)
ip firewall mangle pr
0 chain=forward action=mark-packet new-packet-mark=jetpark passthrough=no
in-interface=LAN
Queue
0 name="Jetpark5MQueue" target="" parent=none packet-marks=jetpark
priority=8/8 queue=default-small/default-small limit-at=5M/5M
max-limit=5M/5M burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s
