Speed test
Hi Guys
Still fairly new to MikroTik wireless at the moment, so any help would be appreciated.
I’ve just setup a PtMP link using a QRT 5ac as the AP and 2 LHG as the clients.
Client 1 can bandwidth test back to the router behind QRT at 90 - 95Mbps
Client 2 also can bandwidth test back to the router behind QRT at 90 - 95Mbps
If client 1 & 2 run bandwidth test back to router behind the QRT at the same time they get around 30Mbps each.
Is this normal behaviour; I expected that with the QRT having 10/100/1000 and supporting much higher data rates that we would not see this sort of contention issue until around 10 clients were connected…am I missing something?
Mark
Are you running with nv2?
Is this with latest RouterOS versions?
What signal strength is being reported?
