...speeds down every 15 days!!! HELP!
Hi. I have Mikrotik 3.10, and on every 15 day I have strange problems: incoming speed getting down to about 5-10 Mbits/s (I have about 50 Mbits/s channel) until manual reboot. I’ve noticed the problem on version 3.20 and downgraded to 3.10 but no luck. Than I turned off all unused modules. The other modules left enabled:
advanced-tools
dhcp
ppp
security
system
The configuration of the box:
MB ASUS P5B-MX
CPU intel Celleron 420 1,6 GHz; cache: 512 KB; cores 1; 65 nm;
MEM DDR II Hunix 512Mb
IDE Flash Disk On Module Transcend 256 mb
Power: Hopley 350w
NICs: 2x  INTEL 100mbit/s PRO.
Graphs of the last fault attached
Incoming speed
Processor usage
Memory usage
LOGS ARE CLEAR - no errors
Any idea? Really need help!!!
I’ll post any configs if needed!! Thanks!!!
