Speedtest is limited
Why is it that my bandwidth on speedtest.net net is always limited only to 0.5Mbps download speed. While using downloader like internet download manager I’ll get at max speed of 8Mbps or utorrent the speed is higher.
My config port 1 to 7 is bridge 1 and port 8 to 9 is bridge 2. All ports have always same bandwidth limits.
thanks,
More information is needed to give a proper answer. Please consider posting your configuration (/export compact) and network diagram (all devices from your PC to the ISP gateway)
Have you tried from the same box, taking the routerboard out of the equation?
I am not seeing what you are, as both direct and through my CRS125, speedtest.net tests show at just about 125% of my advertised ISP speed caps, every time.
