I'm not convinced about that at all.
If we were talking about critical vulnerabilities (like CVE-xxxx), that would be a separate issue.
But when it comes to RouterOS errors, comprehensive testing simply isn’t feasible.
MikroTik lacks the resources required to fully test all functionality across so many active versions.
Consequently, every new release of RouterOS ships not only with new bugs, but also with dozens, if not hundreds, of legacy defects.
This points to a fundamental lack of QA and testing at all stages of development.
To fix this, MikroTik would need to overhaul its entire development pipeline—a shift that would drastically spike OPEX expenses.
Given the current economic climate, that is highly unlikely to happen
- but let's hope for the best. ![]()
The last promotion of [testing] to [stable] and last two promotions from [stable] to [long-term] have been due to CVE issues. And these force users to upgrade under duress to versions they probably wouldn't have if they had a choice. I.e. they upgraded because they wanted the security fixes, not because they want some new feature or even feature bug fix in the new version (which they may not have been affected by anyway because they didn't use that feature).
We can only hope that MikroTik does use some source control tools that would make rebuilding with only specific changes possible without a lot of extra work.
It is obvious that MikroTik currently doesn't do very much regression testing, just based on how many "resgressions" need to be patched after the code ships.
I also understand that there hasn't been a lot of time to respond to the recent AI discovered bugs with AI created exploits. But this is only going to get worse, at least in the short term, while all the technical debt is being repaid. Just look at the number of Microsoft windows patches there have been for the last 3 months. And most of these were AI assisted discoveries and fixes.
