Split horizon on dynamic port
I would like to use bridge horizon on a dynamically added port (more specifically, a PPP connection) to prevent clients in the bridge from talking to each other.
However, I cannot find how to do this. Setting a horizon value directly doesn’t work:
[admin@RouterOS] > /interface bridge port set 10 horizon=1
failure: can not change dynamic port
But I’m also unable to find horizon option in /ppp profile:
[admin@RouterOS] /ppp profile> set 0
address-list          comment              local-address    queue-type       use-encryption
bridge                dns-server           name             rate-limit       use-mpls
bridge-path-cost      idle-timeout         only-one         remote-address   wins-server
bridge-port-priority  incoming-filter      outgoing-filter  session-timeout
change-tcp-mss        insert-queue-before  parent-queue     use-compression
Is it even possible to use bridge horizon on dynamic ports?
Are we talking about a PPPoE server?
No, the PPP connections are PPTP clients who share the same subnet, but shouldn’t be able to communicate with each other:
[admin@RouterOS] > /interface print
10 DRS <pptp-hotspot-1>               pptp-in          1596
11 DRS <pptp-hotspot-2>               pptp-in          1596
12 DRS <pptp-hotspot-3>               pptp-in          1596
13 DRS <pptp-hotspot-4>               pptp-in          1596
14  R  bridge-Hotspot                 bridge           1500 65535
We have about 300 of these clients, all of them are Mikrotik nodes.
Seems you will need to resort to bridge filters then.
