Split hotspot users group
Hi there,
I am using RB433, the hostpos server are for ether3 and wlan1. Both of them is not bridged.
Is it possible to split the user into two groups according to customer / subscriber id ?
let say subscriber ‘admin1’ for hotspot server wireless (wlan1) and subscriber ‘admin2’ for hotspot cable (ether3) and each admin will create their users… and some other will be able to use on both interfaces (low priority).
how to limit the users, so all admin1 users will only can use the servies with wlan1 interface and all admin2 users will only can use the servies with ether3 interface; without having to fill in pool name / pool address field on each users.
Cheers
Paul Darius
UserManager?..
yes… I am using User Manager…
Two groups with the same gateway and the same router, is it possible ?
I tried to create customer / subscriber ‘admin1’ and create the router ‘127.0.0.1’ but then at customer / subscrber ‘admin2’ we can not add the same router as the address already used.
How to make customer / subscriber ‘admin1’ and it’s users only for wlan1 and customer / subscriber ‘admin2’ and it’s users only for ether3 ?
Paul
