Our ISP has assigned us two blocks of static IP addresses and I’m now having problems getting our Router configures correctly.
Original config
- 185.106.134.192/28
- Ports 1-6 assigned to Bridge 1 (DMZ)
- Ports 7-8 used for LAN behind firewall, NAT, Masquerade rules etc
- Bridge assigned IP address 185.106.134.194/28
- Upstream gateway provided by ISP is on Ether1 and has IP address 185.106.134.193
- Default route is via 195.106.134.193
That all works fine. Anything behind the firewall on the LAN has full internet access.
We’ve also got a computer in the DMZ with the static IP address 185.106.134.195 and netmask 255.255.255.240. That works also works perfectly
The ISP have now allocated us a second block of IP addresses: 185.106.134.160/28
We’ve set these up as follows
- Additional address added to the bridge 185.106.134.161/28
- Second computer in DMZ assigned static IP address 185.106.134.166 with netmask 255.255.255.240
This computer cannot access the internet although it can PING 195.106.134.195
What have I missed?
