Hello, I am setting up L2TP on a MikroTik router and would like to know if RouterOS supports split tunneling for L2TP connections.
Can anyone provide specific setup steps or configuration if it is supported? Thanks.
If you’re configuring L2TP over IPsec (which you probably should be) there’s an option in the mode configurations named “split-include” but for you to be able to use it you would have to configure the whole IPsec part by yourself instead of just adding IPsec secret under the PPP profile which is not rocket science but you require a certain level of knowledge about it
