Split Tunneling / PPTP / DHCP
Is there a way that Mikrotik PPTP server can use the DHCP service instead of only using ip pools ?
"The Windows Server 2003 DHCP Server service supports the configuration of the Classless Static Routes option (option number 249). "
I have clients who would like us to hand them a list of routes so that they do not have to enable us as their default gateway or manage individual static routes… and I guess Windows PPTP service uses DHCP option 249 to hand them this. If not, maybe a nice change for a future version - using full dhcp server in mikrotik instead of just handing them an ip from a pool. The WINS and DNS servers options could then go away on the profile because the DHCP server hands those back already.
Thx,
Sam
Support, is it still not possible to support DHCP over PPP to hand out classless static routes?
Is there a recommended alternative? (I was thinking of perhaps in smaller networks handing out just a remote IP from the local subnet pool, and attaching them to a bridge that is already bridged to the local subnet of the physical network?)
UP
actual problem
howto get DHCPOFFER relay to local DHCP ?
up
actual problem
