any one use a sr2 with a splitter and multipul sector antennas does it work well or not or would you be better to use a omni?
I cant speak from experiance here but,
Yould you be better off using sector antenas off seperate radios?
This would let you adjust each radio to the conditions its indevidual antenna “sees”.
Also it would decrece the load on each radio (clients)…
Just my opinion.. ![]()
Things that make you go Hmmmmm…
Craig
I think with a splitter you couldn’t get the SWR to match right and probably burn out the radio ?
Sam
