Sporadic disconnections NAT NAT
Hello everyone,
I’ll try to describe my problem.
I have a medium sized network with a RB3011 as router/firewall/cap manager/VPN
Behind this, several switches are connected across the entire site.
Directly behind the RB3011 is a CRS328 and a CRS354(48Poe 4 S+ 2 Q)
In front of the RB3011 there is another Speedport router for hybrid access (DSL and 5G hybrid), there is no way to access the Internet without this device!
There are 5 VLANs in the network that are accessible via all switches.
Some of the networks are broadcast to sen APs via the Capsman.
In one of the networks I sporadically have the problem that there are dropouts in the direction of the Speedport router.
To narrow this down more precisely, I have set up Netwatch on some switches to the IP of the Speedport and to 8.8.8.8.
If the error occurs, I only get the error message from the switches but not from the router.
The error also only occurs when a mobile phone connects to the network via WLAN, according to my current assessment.
We have Sonos loudspeakers in this network/VLAN, which actually always play the radio, so the disconnection is clear and audible.
When the error occurs, however, you can no longer get a speed test or even other connections to the outside world in the entire network.
Everything works on the network itself.
I don’t want to commit myself 100%, but I think the error occurred when the CRS354 was installed.
Do you have any ideas on how and where I can look, what I can do to narrow down the fault further?
How can I measure the cancellation?
A company has already had a look at it, unfortunately without success so far
Thank you very much
EDIT:
What I would like to add: in these failures I get the message to the RB3011 “No SNMP Data collection” from the Zabbix server running on a Hyper-V .
AND from Time to Time, i can‘t connect to the RB3011 over IP-Adress, over the mac of the rb3011 it works fine.
Hi guys,
i actived debug logging on my RB3011. I found some logs on this time, where my connection still lost.
27.12.23 20:13 Debug rb3011_alzey syslog start CRL update
27.12.23 20:13 Debug rb3011_alzey syslog type: simple, host: 8.8.8.8 ] attempts: 1
27.12.23 20:13 Info rb3011_alzey syslog type: simple, host: 8.8.8.8 ] attempts: 1
27.12.23 20:13 Debug rb3011_alzey syslog type: simple, host: 192.168.2.1 ] attempts: 1
27.12.23 20:13 Info rb3011_alzey syslog type: simple, host: 192.168.2.1 ] attempts: 1
27.12.23 20:13 Debug rb3011_alzey syslog received Router Advertisement on unconfigured ether3-DSL-Backup from fe80::1
27.12.23 20:13 Debug rb3011_alzey syslog received Router Advertisement on unconfigured br_Freifunk from fe80::1:aff:fe56:106f
27.12.23 20:13 Debug rb3011_alzey syslog received Router Solicitation on unconfigured br-lan from fe80::969f> :3eff:> fe54:7d26
ether3-DSL-Backup is my actual Port to the Internet Router ( Speedport ).
I dont have set up any ipv6 yet. I still wondering, why i get this errors.
Thank you for help
does anyone have any ideas, or have I not described the question well enough?
In the meantime, I have replaced the RB3011 temporary with a similarly configured RB5009. The sporadic failure or the inaccessibility of the route to the Speedport still remains.
