Any update on the driver / intergration of the 598U / 300 series of Sprint cards?
More accuratly.. looking for status information.. IE signal levels Etc…
Also still having some the like to drop and re-connect…
And can someone PLEASE tell me at what section of the code does it state “Hunged up” (Look at loging for ppp) When the board first starts up, if there is a “connection issue” / or a drop and re-connect, the log shows “Hunged up”. Durring normal opperation (after a while) if the modem reconnects, the logging shows “Hung up”… NO “ed” at the end of the status log entry.. this should help in locating the intermittant drops that SOME cards seem to face… also if there is a way to detect if the card is changing towers (IE a far side ESN change, a log entry can be made) then we can deturman if we have a bouncy cell situation and try something like a dirrectional antenna or something like this to avoid the problem cell..
