Hmm. You said it is not possible to get data from user manager database.
Is there anyway?
I am working on a developement project for a time-share resort with vb.net and installing their wifi network (using all Mikrotik of course). My client would like their guests to have free wifi during their stay and others around the resort to be able to use the network but pay via hotspot.
I would like to have the ability to automatically create new login id and password (account in user manager from my app) for their guests once they make a reservation and retrieve that information from user manager to store in my external database. That way when the guest checks in they get their username and password printed on their registration card. I could do that if I knew the best way to interface with user manager from my vb app.
I am hired to write a custom app to eliminate business processes and not create new ones. Plus the staff at the resort are technically challenged.
So, is there a way I can interface with user manager? I see the API and it appears I can do everything from there. Is that correct?
You should be able to do that. I do the same with FreeRADIUS, except I interface directly with the SQL database using php. You would be using the functions in “/tool user-manager” instead.
That what I was thinking. I don’t have access to a user manager this weekend to check it out but I will post in the next week or two to disclose what I find.
I know the database file is in SQLite 3 format I’m able to transfert the file SQLdb to my hardrive and browse it. But I need to directly acces it from my .net program. Any idea?
I have made progress, I’m reading and writing without any problem from my VB.net application to the sqldb database. The only problem I still got is that usermanager seem to refresh the database. I think there is to version of the database. One is save on ROM and one seem to be load in memory. I make my change and they are in the file SQLDB but I need to enter in the web interface of userman make a change to make my change “active”. Is this releated to some Timestamps in the database? Is there a command to force reload of the SQLDB in memory?
As @sergejs suggests, the data inside the database is not very usable. Each thing, like a user, is the “id” and binary blob (likely some serialized C struct) in some table.
So while any SQLite client can open the um5.sqlite file, including .NET… You’d have to parse the undocumented binary data structures to do anything, since the columns are not “expanded” into the actual attributes. And you do not get .sqlite database unless you do some optimize or have it running for a while. The .wal cannot be opened, only a um5.sqlite thing.
