However, with this configuration, my inter-vlan routing is reduced to the max limit set in the downstream queue (300M), which has the bridge interface set as “parent”. When I stop the queue, the limit is lifted and I can reach near wire speed.
So, I’m trying to understand how to configure the queues so that the WAN traffic goes through them, but the LAN is not limited.
I had the exact same issue since I also use interface queue (with fq_codel in my case). There is an easy solution. First, you need to apply the queues only to unmarked packets, which is what you are already doing (“packet-mark=no-mark”).
Then you need to mark your inter-VLAN traffic (adjust lists and mangle passthrough as needed):
add name=local
add interface=vlan101 list=local
add interface=vlan102 list=local
/ip firewall mangle
add action=mark-packet chain=forward comment=inter-vlan in-interface-list=local new-packet-mark=intervlan out-interface-list=local passthrough=no
Packet mark can be anything, we are not matching on it. We just need some mark to satisfy the “no-mark” filters.
But the mangle rule won’t work because of fasttrack, so you need to adjust the latter to exclude all marked traffic.
Although marking packets is heavy on CPU, this approach is still better over having to completely disable fasttrack in order to use simple queue where you don’t involve the bridge at all. And of course, it’s better than dealing with limited inter-VLAN bandwidth.
With this configuration on a hAP ac2 I can achieve 530 Mbit/s single stream iperf inter-VLAN bandwidth, 680 Mbit/s with 4 streams. I’m sure you won’t have any troubles reaching full gigabit on RB5009.
If you have no vlans and just want to get full speed local bridge traffic while using a queueTree on the bridge to smooth downloads, would it be sufficient simply to just do these two steps?:
Added the mangle rule.
Code: Select all
[RB5009] > ip firewall/mangle/export
/ip firewall mangle
add action=mark-packet chain=forward comment=“Mark LAN packets for queue bypass” in-interface-list=LAN new-packet-mark=LAN out-interface-list=LAN passthrough=no
And updated the fasttrack filter rule.
Code: Select all
[RB5009] > ip firewall/filter/export
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related hw-offload=yes packet-mark=no-mark
You don’t need to do anything in this case. LAN to LAN traffic doesn’t go through the router CPU, so it doesn’t hit queues or firewall. It will be switched in hardware by the switch chip.
