hello,
I have a mikrotik and squid-linux, it´s work. But i have problems on load images. The images time out for load expires. What can be here?
I use this dnat:
ip firewall nat
add action=dst-nat chain=dstnat comment=“” disabled=no dst-port=80 protocol=tcp to-addresses= to-ports=3127
I try this:
/ip firewall mangle
add chain=prerouting protocol=tcp dst-port=80 action=mark-routing
new-routing-mark=http passthrough=yes
/ ip route
add dst-address=0.0.0.0/0 gateway=10.1.2.4,10.1.2.3,10.1.2.2
check-gateway=ping scope=255 target-scope=10 routing-mark=http comment=“”
disabled=no
iptables -t nat -A PREROUTING -i eth0 -p tcp -m tcp --dport 80 -j REDIRECT --to-ports 3128
My squid.conf
# SQUID 2.6.STABLE14 - MIKROTIK ROS
# TAG: http_port
# Porta na qual o squid irá escutar # modo transparente, nao ha necessidade de configurar o browser
http_port 3128 transparent
# TAG: icp_port
# Porta na qual o squid irá enviar/receber requisicoes icp
icp_port 3130
# TAG: cache_peer
# Usado para especificar uma hierarquia proxy
#cache_peer parent.foo.net parent 3128 3130 [proxy-only]
#cache_peer sib1.foo.net sibling 3128 3130 [proxy-only]
# TAG: hierarchy_stoplist
# Determina as palavras que serao mandadas diretamente para o cache
hierarchy_stoplist cgi-bin ?
# TAG: cache
# Lista de ACLs, caso mal-configurada, causa resultados indesejados
acl QUERY urlpath_regex cgi-bin \?
cache deny QUERY
# TAG: broken_vary_encoding
# Muitos servidores nao tem suporte a on-the-fly Content-Encoding, retornando algumas variantes
acl apache rep_header Server ^Apache
broken_vary_encoding allow apache
# TAG: cache_mem (bytes)
# Tamanho da memoria usada pelo cache
cache_mem 8 MB
# TAG: cache_swap_low (percent, 0-100)
# TAG: cache_swap_high (percent, 0-100)
# Quando o squid ira sobrescrever os arquivos mais velhos do cache
cache_swap_low 90
cache_swap_low 90
# TAG: maximum_object_size (bytes)
# Tamanho maximo do objeto que o squid ira salvar no disco
maximum_object_size 4096 KB
# TAG: minimum_object_size (bytes)
# Menor objeto salvo no disco
minimum_object_size 0 KB
# TAG: maximum_object_size_in_memory (bytes)
# Tamanho maximo do objeto que sera mantido na memoria cache
maximum_object_size_in_memory 8 KB
# TAG: ipcache_size (number of entries)
# Tamanho do cache dos ips
ipcache_size 1024
# TAG: ipcache_low and ipcache_high (percent)
# Determina quando os ips salvos serao substituidos
ipcache_low 90
ipcache_high 95
# TAG: cache_dir
# Diretorio onde sera salvo os arquivos do cache
cache_dir ufs /var/log/squid/cache 100 16 256
# TAG: access_log
# Local onde ficara armazendo as informacoes de acesso ao cache
access_log /var/log/squid/logs/access.log squid
# TAG: cache_log
# Arquivos que contem informacoes sobre o cache
cache_log /var/log/squid/logs/cache.log
# TAG: cache_store_log
# Local onde ficara armazedo as atividades do cache
cache_store_log /var/log/squid/logs/store.log
# TAG: pid_filename
# Onde ficara armazenado o id do processo do squid
pid_filename /var/log/squid/logs/squid.pid
# TAG: refresh_pattern
refresh_pattern ^ftp: 1440 20% 10080
refresh_pattern ^gopher: 1440 0% 1440
refresh_pattern . 0 20% 4320
# TAG: acl
# Define uma lista de acesso
acl all src 0.0.0.0/0.0.0.0
acl manager proto cache_object
acl localhost src 127.0.0.1/255.255.255.255
acl to_localhost dst 127.0.0.0/8
acl SSL_ports port 443
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl Safe_ports port 443 # https
acl Safe_ports port 70 # gopher
acl Safe_ports port 210 # wais
acl Safe_ports port 1025-65535 # unregistered ports
acl Safe_ports port 280 # http-mgmt
acl Safe_ports port 488 # gss-http
acl Safe_ports port 591 # filemaker
acl Safe_ports port 777 # multiling http
acl CONNECT method CONNECT
# TAG: rede local
# Definicao da rede local
acl rede_local src 0.0.0.0/0.0.0.0
# TAG: http_access
# Permite ou nega acesso a lista de acesso
http_access allow manager localhost
http_access deny manager
http_access deny !Safe_ports
http_access deny CONNECT !SSL_ports
http_access allow rede_local
# Nega os que nao estiverem na lista de acesso
http_access deny all
# TAG: icp_access
# Permite ou nega o acesso ao icp
icp_access allow all
# TAG: cache_mgr
# Administrador do cache, caso haja algum problema
cache_mgr suporte@freirenet.com.br
# TAG: cache_effective_user
# Define o usuario do cache
# cache_effective_user nobody
# TAG: cache_effective_group
# Define o grupo do cache
# none
# TAG: error_directory
# Define a linguagem de erros
error_directory /usr/share/errors/Portuguese
# TAG: coredump_dir
coredump_dir /var/log/squid/cache
