squid proxy!!! need help..
Can anyone help me…
set Parent Proxy in RouterOS proxy and disable caching :slight_smile:
thanks.. it works!!!
HI Arjune
Would you mine if you share your mikrotik config and script config in squid please send to my email myron@iwantlemonjuice.com
Thank You
when you visit whatismyip.com
is it showing you actual local ip??
and may i know for client billing what application are you using??
we have developed a billing software for mikrotik
it’s raduis based and uses squid to accelerate web browsing
you can view connection log of users, sites visited, set speed limit etc from the application
and we are about to start commercial sale of it
so can you please tell will you buy this kind of app if the price is really good
I am just using the squid for testing purpose. Currently I am using mikrotik built in web-proxy server…
you can find the squid configuration in
http://aacable.wordpress.com/2012/01/11/howto-cache-youtube-with-squid-lusca-and-bypass-cached-videos-from-mikrotik-queue/
and or mikrotik configuration..
set the parent proxy : ip of squid server and port
I am currently using Mikrotik Usermanager…
I am intending to user DMA Softlabs Radius Manager
nice top!
Hi There
How do I make My Proxy work with userman?
RouterOS Web Proxy cannot authenticate users by name/password, if you’re talking about that
