hello masters
I have a problem on the squid in tproxy mode and it is that squid
return Error “110 connection
the timeout.” for all Requests on port 3129, which is related to tproxy
Of course, by eliminating the code
ip route add local 0.0.0.0/0 dev lo table 100
Problem solved, but in this case, Squid does not record any activity log.
i had attached the network topology.
In this network, 185.12.32.1 is gw for both of the client and squid. it is set
to That route the client communication to the squid and then, squid
connect it to the internet by using this gw and also redirect port 80
to 3129 and tproxy to cache the data.
The gw is connected to the Internet and also it is the bgp for these
IP addresses.
