SQUID with Mikrotik Proxy or with Cisco WCCP
Dears
I was use REDHAD box with SQUID web Cache , I have more than 200 client connect to internet , I have quistion .
which one better use Mikrotik (( Firewalll + web proxy )) to switch the http requist , or use Cisco with WCCP mode http://www.sublime.com.au/squid-wccp/ , or use REDHAD firewall .
i was tested the mikrotik use P4 with RAM 1G , when i enable redirect firewall CPU load upto 100%
what is the best solve , also i need unlimeted download from Cache , My client connect PPPoE with diffrent profiles.
Regard
I would add a dst-nat firewall rule to redirect all tcp port 80 traffic to port 3128. Then enable your webproxy on port 3128 on your MT. Then I would make use of SQUID as your parent proxy.
There are other ways of doing it too, but I find redirecting only port 80 traffic to work the best.
I also think SQUID is a much better proxy. In the later versions of MT, some features like max-file-size has been removed. In 2.9.6 you had the function to choose the maximum file size to be cached.
how would you send requests to squid proxy??? just add parent proxy and type squids ip address?
