SR2 strange problem or normal,UBIQUITI-Mike please reply
hi,
I have 133(3-card board) I put only one SR2 in it and keep normal setting like band :2.4 b/g and scan it will scan for 5-6 seconds and router restarts, this time the router doesnt detects SR2, so I restarts it again, (this time manually) and this time SR2 is back online I again change band from 2.4b only to 2.4 b/g and start scanning, the above problem repeats, so this time I disable the ETHER2 and ETHER3 and restart manually only the scan this time runs for 15-20seconds and then again auto reboot.
Is this a power issue ???
now this time i have put this on RB532rev5 and not A one it is on for about 10 minutes no issue.
Also I have put one of the problem, creator bugger on IXP from gateworks that is also creating problem
WHAT IS THIS ??? WHY IS THIS ???
Has this happened to anyone else? I have been using SR2 on 112 only till now this is my first try on 133…
groups early response will be highly appreciated.
regards
MKSB
PS: RB532 working ok now for 12minutes :wink:
OK NOW THE PROBLEM IS REPEATING ON RB532 ALSO, I DONT UNDERSTAND IS THIS FAULTY CARDS, HARD TO IMAGINE 10 FAULTY SR2s, PLEASE GUIDE ME,
REGARDS
MKSB
what are you using for power ?
95% power issue
whats ur power??
18v?
whats your ethernet cable and whats the length u are using
i m using a good brand cable S&M 30meter 2 XR-2 cards, works perfect 18v 1 amp
i repalced it to 19v 3amp laptop power supply which is more than perfect
using SMPS based power supply 18v 1.1 A or v 1.0 A , CAT 6 cable from AVAYA
