Hi guys,
SR2 (U.fl / MMCX) - Which antenna is a and which is b?
- Is it possible to set both of them to transmit (TX)???
Hi guys,
The MMCX is B
No, but I’m fairly sure you could run them in diversity mode - I’ve never tried.
Thanks pilot ![]()
I dont think you can use diversity in mt
Diversity is not supported, and as far as I know won’t be.
MMCX is B, and that’s the one I always use.
So, MMCX is the better one to use???
someone pls respond .. i want to know this too
MMCX is a better connector than u.fl.
Both with regards to RF as well as Mechanically.
