Hi guys,
Please has anybody tried Ubiquiti (SR5) Super Range 5 400mW 802.11a 5.8GHz MiniPCI card (https://www.mikrotik.com/interfaces.php#linx1) on a Router Board 511 ![]()
Did it work ![]()
Iwa ![]()
Hi guys,
Did it work ![]()
Iwa ![]()
It should work…
Yes I think so…
But I want to be sure because on this link https://www.mikrotik.com/interfaces.php they said Wireless Interfaces
(SR5) Super Range 5 400mW 802.11a 5.8GHz MiniPCI card High power 400mW 5.8GHz MiniPCI wireless card, compatible with RouterBOARD 230 and RouterBOARD 532. Should not be used with RouterBOARD 14 four port and RouterBOARD 18 eight port adapters!
I expect them to also comment on Router Board 511
The problem is high power these wi-fi cards drain.
Local reseller told me that I could use max 2 of the on 4 port and 8 port cards.
Anybody knows how much power does a Motherboard provide at PCI slot ?
I know, not enough ![]()
Normis, Arnis, Edgars, Megis and uldis please comment. This is very urgent as I need to place an order now.
Will SR5 400mW card work well on RB511 ![]()
yes it will work (just got some more confirmations from other people in this room)
Will an SR5 and an SR2 card work on a RB511? Or on an RB532?
both! the question is - how many of them do you want to use. maximum of 2 is recommended, more can cause power problems
Thanks. Thats what I needed to confirm.
Thanks alot guys!
