On both 2.9.40 and 2.9.35 I dont get the 20MHZ option for the SR9.
I see 5 and 10mhz channel widths..but no 20 as i see advertised everywhere.
any ideas?
tks
any ideas?
tks
Uhm, the 20MHz option isn’t advertised as such. 20MHz has been the defacto channel size on 802.11-whatever for some time, so it’s implied when you select a “normal” band setting. Setting it to any of 2.4ghz-b, 2.4ghz-b/g, or 2.4ghz-onlyg will give you 20MHz channels. There is no “2.4ghz-20mhz” option if that’s what you’re looking for.
– Nathan
